AEG Lavamat L12700ViT dryer problem
Postby R_Stead » Sat Jan 14, 2006 3:12 pm
Machine is 18 months old, dryer used 4 times, never overleaded, but no longer working. Washing functions are fine.
On removing top cover found belt off what appears to be motor for blowing in warm air. Refitted belt but still not working. Seems that either motor has gone or heating elements may have blown due to overheating if motor stopped, or both have gone. :(
Is there a reset switch or kick out relay located somewhere in the machine that I could try? Any advice would be much appreciated.
PS should have mentioned, both dryer settings appear to operate correctly, drum turns, timer counts down normally, no error codes.
R_Stead
Re: AEG Lavamat L12700ViT dryer problem
Postby Martin » Sat Jan 14, 2006 3:25 pm
When refitting the drive belt does the motor & fan spin very freely I wonder?
Postby R_Stead » Sat Jan 14, 2006 3:43 pm
Yes, both spin freely.
R_Stead
Postby Penguin45 » Sat Jan 14, 2006 8:41 pm
There should be a manual reset thermostat in the top somewhere. Look for a red push button. Power off before sticking fingers in.
If there has been a trip out, it will be because of lack of airflow caused by the belt coming off. A new one is part number 1240827-30/1; an email to spares@ukwhitegoods.co.uk should you wish to order.
Postby R_Stead » Sun Jan 15, 2006 1:52 pm
Thaks very much - I've ordered the part, and will post update when I have fitted it.
R_Stead
Postby R_Stead » Wed Feb 08, 2006 10:34 pm
Ended up calling in an engineer. He said the belt was undamaged, and he got the dryer going, and working OK. Unfortunately after a few minutes the belt worked its way off the spindles. The engineer said he did not understand how the spindles could have got misaligned, and that he does not know how to fix the problem. :?
Any ideas please?
Thanks again
R_Stead
Postby macmini » Wed Feb 08, 2006 11:37 pm
what were the problem with the dryer?
macmini
Postby Dave_Conway » Wed Feb 08, 2006 11:38 pm
One of the pulleys on either the motor or fan unit are poorly manufactured or misaligned, it can't be anything else really :?
Given the little use the dryer has had it all points to a manufacturing defect.
Have a chat with Electrolux (who own AEG):
www.serviceforce.co.uk and see if they can help rectify this for you :)
Users browsing this forum: keepitsimple, Specialist01269 and 71 guests
In total there are 73 users online :: 2 registered, 0 hidden and 71 guests (based on users active over the past 30 minutes)
