by freelandm » Wed May 16, 2012 5:31 pm
Hi All
This machine didnt empty after a wash cycle and the control knob was turning around so i left it to investigate today.
Reset as per usual process and the pump drained the machine i thought sorted but it will not spin.
Now i have had the pump off and removed the usual coins, hair clips etc. the impeller is free.
when you switch on the machine to start a cycle there is a pause then the pump starts then after a short while the knob starts turning around, i have counted the indicator light flashes and every time i count 9.
Any help would be much appreciated.
Matt.
freelandm
by Martin » Wed May 16, 2012 6:09 pm
freelandm wrote:i have counted the indicator light flashes and every time i count 9.
If I'm not mistaken that error indicates a circuit board error (EEPROM failure). I wonder if, while you were clearing the pump spilt water anywhere near the circuit board?
- Appliance Guru
by freelandm » Wed May 16, 2012 6:16 pm
Hi Martin
Thanks for the prompt reply.
No water near the PCB are you sure re diagnosis, other than that i will pull the board out and give it a coat of looking at.
If it is the board as you say is that part available still?
Matt
freelandm
by Martin » Wed May 16, 2012 6:33 pm
freelandm wrote:No water near the PCB are you sure re diagnosis,
Not certain at all but Ariston are synonymous with dodgy PCB's and the connections to and from them.
- Appliance Guru
by freelandm » Wed May 16, 2012 6:45 pm
Thanks Martin.
Had a quick poke around the EEPROM are not supplied with the control board either
May be time to get shut of it
Thanks.
freelandm
- ariston awd 12s margherita
by _brammers » Mon Jan 31, 2005 6:55 pm
- 10 Replies
- 2820 Views
- Last post by Dave_Conway
Wed Feb 02, 2005 2:46 pm
- Ariston Margherita (Again)
by aristoff » Sun Mar 19, 2006 2:49 pm
- 670 Views
- Last post by aristoff
Sun Mar 19, 2006 10:57 pm
- Ariston Margherita LBE 12X
by CIM64 » Tue Jun 20, 2006 9:29 pm
- 772 Views
- Last post by iadom
Tue Jun 20, 2006 10:00 pm
- ariston Margherita awd 12 s
by dunkbuk » Mon Nov 13, 2006 4:25 pm
- 744 Views
- Last post by dunkbuk
Tue Nov 14, 2006 8:08 am
- Ariston Margherita CDE 12X
by fletcher » Thu Nov 15, 2007 10:28 pm
- 5 Replies
- 1388 Views
Tue Nov 20, 2007 11:17 pm
Users browsing this forum: No registered users and 63 guests
