by Kielykid64 » Tue Oct 05, 2010 8:41 am
I was called to service this Dryer as it It was just giving 2 beeps and Nothing else, Checked the water chamber on underneath the conderser pump cleared out the fluff. cleaned the probe in front at the lint filter and the sensor at the element had a coating of lint . I didn't remove the motor side of the cabinate , did I miss something ? There are no burn marks, the element is metering OK. I was compeatly beaten on this one !
Had to walk away,
Thanks ,
Maurice
Kielykid64
- Appliance Forum User
by don » Tue Oct 05, 2010 9:32 am
Hi Maurice
If you are trade then why not apply for
trade access there is so much more info to be had.
Don
don
by nomadPaul » Tue Oct 05, 2010 5:10 pm
If it just beeps twice on trying to start , but doesn't actually start , then it could well be the door lock faulty , not seeing the door in the closed position.
nomadPaul
- Appliance Forum Veteran
by wizard » Tue Oct 05, 2010 6:57 pm
I had one of these doing exactly this just last week. I came to the same conclusion as nomadpaul, so checked the door lock and connections to pcb. No faults found but when it was all back together it ran perfectly. Put it down to a poor connection on the pcb. It'd be worth giving all the connectors a wiggle. Wizard
If you take out enough screws, it'll come apart !
wizard
by Kielykid64 » Wed Oct 06, 2010 8:52 pm
Thanks Guys, I will keep it in mind for the next One !
Maurice .
Kielykid64
by octumnal » Wed Jun 27, 2012 4:24 pm
how is the interlock replaced on this,cant see any screws?
octumnal
by Martin » Wed Jun 27, 2012 5:50 pm
octumnal wrote:how is the interlock replaced on this,cant see any screws?
Slide 'n click fitting.
- Appliance Guru
- Bosch WTL 5500GB Condenser Dryer
by Top Loader » Sat Mar 24, 2007 9:25 am
- 4 Replies
- 1667 Views
- Last post by kjmac1980
Mon Mar 26, 2007 10:42 pm
- Bosch Condenser Dryer WTE86304GB
by DanAllen » Mon Sep 29, 2008 9:01 am
- 959 Views
- Last post by Goatboy
Mon Sep 29, 2008 11:21 am
- Bosch WTL 55 Condenser Dryer: Pump Failure?
by yellerKat » Wed Jan 19, 2005 8:39 pm
- 12 Replies
- 3171 Views
Tue Jan 25, 2005 12:25 am
- Bosch WTE86304GB Condenser Dryer - any good???
by bargepower » Thu Nov 09, 2006 12:23 pm
- 570 Views
- Last post by Martin
Thu Nov 09, 2006 12:30 pm
- Bosch Classixx WTE84103GB Condenser Dryer – Yes or No!
by Melv » Tue Nov 27, 2007 11:29 am
- 845 Views
- Last post by gegsy
Wed Nov 28, 2007 10:17 pm
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 17 guests
