by owy » Mon Jun 18, 2012 5:13 pm
Hi, I recently had an error code on my machine which said i had a motor fault. I changed the carbon brushes and the error code has gone. unfortunately it has been replaced by all lights on on one side and the top light(wash) on the other. The start light does not illuminate and the door does not lock. any suggestion please
owy
- Appliance Forum User
by lasty » Tue Jun 19, 2012 12:11 pm
hi,if you turn wash knob to the off position then turn it to the 6 oclock spin position then press and hold the spin speed button then turn the knob to the 7 oclock position keep holding down the spin speed button for a further 5 seconds then turn the knob to the off position,this will reset the board, however it can take a few times to reset it when you have not done it before,hope this helps
lasty
- Regular Appliance Forum User
by owy » Tue Jun 19, 2012 3:32 pm
lasty wrote:hi,if you turn wash knob to the off position then turn it to the 6 oclock spin position then press and hold the spin speed button then turn the knob to the 7 oclock position keep holding down the spin speed button for a further 5 seconds then turn the knob to the off position,this will reset the board, however it can take a few times to reset it when you have not done it before,hope this helps
THANKS i will try that now.
owy
by owy » Tue Jun 19, 2012 3:40 pm
Hi Lasty just a quick question
does this work with touch sensitive buttons?
owy
by owy » Thu Jun 21, 2012 3:49 pm
hi ive tried that and it doesnt seem to work anyone have any other ideas?
owy
by Martin » Thu Jun 21, 2012 4:20 pm
Unplug the motor, then perform the reset procedure, then plug the motor back in..!
- Appliance Guru
by owy » Thu Jun 21, 2012 5:15 pm
ok cheers i'll give it a go.
owy
by owy » Fri Jun 22, 2012 1:14 pm
hi martin thanks for the advice but im just vwiondering does this work with the touch sensitive buttons, as when i hold the spin button there is no button as such to hold in, sorry if im being really dumb here.
owy
by Martin » Fri Jun 22, 2012 5:09 pm
owy wrote:sorry if im being really dumb here.
Before I answer, can I just ask if you have first disconnected the motor plug?
- Appliance Guru
by owy » Sat Jun 23, 2012 11:41 am
i have disconnected the motor plug and tried the reset and then connected the motor plug back in but still no change. Iam at the point of giving up and buying a new machine(not an option i will take lightly) I have an engineer coming out this afternoon at a cost of £25, i dont really know what else to do
owy
by steve1 » Sat Jun 23, 2012 2:45 pm
hi
faulty pcb module?
steve1
by owy » Mon Jun 25, 2012 10:08 pm
hello again, thanks everyone for your help.Ii have now fixed the problem. it was just a reset problem Lastys solution was the correct one unfortunately when i first turned the knob to 6oclock i should of waited for two flashes of the lights then moved it to 7 oclock, then release th spin button and turn to off, this instantly reset the machine. One again thanks for all the suggestions.
owy
- LG TDC70040E wrong capacitor start fitted?
by draken » Mon Oct 29, 2007 7:58 pm
- 4 Replies
- 1374 Views
- Last post by draken
Tue Oct 30, 2007 7:53 pm
- Hotpoint WD420 wont spin (not brushes)
by folleyball » Fri Nov 11, 2011 10:58 pm
- 4 Replies
- 716 Views
- Last post by folleyball
Sun Nov 13, 2011 4:36 pm
- Candy CNW 136 Wont start
by haf1zur » Sun Jan 24, 2010 5:27 pm
- 1370 Views
- Last post by haf1zur
Thu Jul 29, 2010 9:40 am
- HOOVER HNL 9146 Z -- WONT START
by HUW2796 » Mon Apr 23, 2007 6:08 pm
- 5 Replies
- 1155 Views
- Last post by HUW2796
Mon Apr 30, 2007 9:22 am
- Hoover AAA 160 wont start cycle
by Kvew » Sun Jun 24, 2007 11:19 pm
- 805 Views
- Last post by Kvew
Users browsing this forum: Google Adsense [Bot] and 28 guests
