by Bishbashbosch » Mon May 22, 2006 10:22 pm
After sludge & scale from the drain pipe caused the drain pump impeller to fall off, I'm having problems with it falling off regularly. The pipes are clear of any scale - it seems that the impellor is a pushfit onto the shaft & is too lose. Can I get a new impeller or is the only fix a new pump assembly?
Bishbashbosch
- Appliance Forum User
by Penguin45 » Mon May 22, 2006 10:42 pm
Yup, pump time - Bosch's own pump is p/no 144305 - about £48 plus VAT, p+p etc. Or you can get exactly the same thing here:
http://www.ukwhitegoods.co.uk/modules.p ... cts_id=412
At a rather more sensible price, in a nice brown box.
Once the impellor's been knocked off, it will never go back on properly........
by Penguin45 » Mon May 22, 2006 10:53 pm
by Bishbashbosch » Wed May 24, 2006 2:22 pm
Thanks for the speedy reply! Should be getting my pump tomorrow - looking forwards to smelling fresh again...
Bishbashbosch
by Dave_Conway » Wed May 24, 2006 2:57 pm
Out of interest, where did you get one from in the end ?
- BOSCH WFL 2260 NOT DOING ANYTHING!!! HELP!! PUMP BROKEN?
by intimidator » Fri Feb 09, 2007 10:27 pm
- 14 Replies
- 4178 Views
- Last post by intimidator
Mon Feb 12, 2007 6:55 pm
- Bosch Maxx WFL 2450 Drain Pump Cap Removal
by rungidung » Mon Jan 30, 2006 3:51 pm
- 457 Views
- Last post by rungidung
by rungidung » Mon Jan 30, 2006 3:52 pm
- 13 Replies
- 2405 Views
- Last post by Dave_Conway
Thu Feb 02, 2006 9:33 am
- Bosch WFL2000 cannot remove drain pump cover
by Spookytooth » Thu Mar 22, 2007 7:42 pm
- 1056 Views
- Last post by Spookytooth
Thu Mar 22, 2007 10:11 pm
- Bosch WFL2450 drain pump impellor loose ?
by vicki01 » Sat Jan 12, 2008 7:03 pm
- 4 Replies
- 1511 Views
Fri Dec 05, 2008 1:31 am
Users browsing this forum: Dazmufc and 50 guests
