Bosch WOK2001GB
Bosch WOK2001GB
Postby Countrylass » Wed Nov 19, 2008 6:58 pm
Hi, we have been having problems with our top loader Bosch washing machine. All the lights flash and an error code of 07 comes up. Is this a fixable problem?
Countrylass
Postby nomadPaul » Wed Nov 19, 2008 9:20 pm
Error 07 normally means that the drum lid is open
nomadPaul
Re: Bosch WOK2001GB
Postby Countrylass » Thu Nov 20, 2008 5:46 pm
Thanks. Would it still be the drum lid if the washing machine goes to start the program and then starts flashing? Does the drum lid have a sensor?
Countrylass
Re: Bosch WOK2001GB
Postby gegsy » Fri Nov 21, 2008 12:35 am
When you close the lid and select prog and then press start, is the lid locked or can you open it?
If you can open, then most culprit is the door interlock.
Available from spares@ukwhitegoods.co.uk , quoting p/no 263334
Power off if you are to attempt any work on the appliance :plug:
Greg
gegsy
Re: Bosch WOK2001GB
Postby Countrylass » Fri Nov 21, 2008 5:20 pm
We have given it a good clean today and that has fixed the problem with the flashing lights. Once we have fixed it back up to the water, I'll let you know if we have managed to fix it (fingers crossed). Thanks for your help so far
Countrylass
Re: Bosch WOK2001GB
Postby Countrylass » Sun Nov 23, 2008 3:12 pm
Hi, we have connected it up to the water and are still getting the flashing and 07. The lid won't open once the error code is on. We turned the water on, then the power, set to Easy care wash at 60, all the correct lights on, then as soon as it goes to start the program straight to error. Is there anything else which could be causing this problem?
Countrylass
Postby helo_75 » Sun Nov 23, 2008 3:44 pm
yep, the lid switch !
helo_75
Re: Bosch WOK2001GB
Postby Countrylass » Thu Dec 04, 2008 3:41 pm
Hi, the spare parts arrived yesterday from Bosch and we finished fitting them today. We put a new hook and switch in and it still doesn't work. With the dial turned to pump nothing happens before the error code comes on and set to quick wash it gets as far as turning the drum round half a turn before the error code comes on. Is there anything we have missed which could be causing this problem.
Thanks in advance
Countrylass
Users browsing this forum: No registered users and 46 guests
In total there are 46 users online :: 0 registered, 0 hidden and 46 guests (based on users active over the past 30 minutes)
