We accidently stopped a wash cycle midway, the washing machine is now stuck, the conditioner light keeps flashing, the machine is just past its warranty date, i've tried every solution on the internet to no avail, i am hoping one of you would be able to help
I've tried the solution most commonly listed to reset the above model, which is
turn off (switch only) -> Set dial to 90 degree wash -> Turn on holding the start / cancel button -> Start LED flashes -> Turn Dial to spin -> Hold Start / Cancel button for another three seconds
Nothing happens at all
On Releasing teh Start / Cancel button, all the LED's flash, if I then press the Start / Cancel button again, it begins a manual wash cycle, i have to advance through the cycle by pressing the Start / Cancel button each time, for Eg : It first fills the drum with water and waits, on pressing Start / Cancel it starts washing, then on press of Start / Cancel it drains, spins etc, this is dangerous as for eg the machine might be spinning infinitely unless the Start / Cancel button is pressed, I can't get the machine to actually restart the complete program again, What is the best way forward, how do i reset the da** thing, I've been pulling my hair trying to sort this out
