Crusader condensing dryer: Empty water container light
Postby invicta » Tue Jan 22, 2008 10:14 am
The empty water container light stays on after container has been emptied & this inhibits the heaters coming on.
Any suggestions?
thks :
invicta
Re: Crusader condensing dryer: Empty water container light
Postby iadom » Tue Jan 22, 2008 10:23 am
Possibly sticking or faulty float micro switch, could also be gunged up float chamber.
Model number is always a good way to help us help you. :wink:
Jim.
Postby invicta » Tue Jan 22, 2008 4:09 pm
Sorry; Model number is 37667.
How do you get to the float switch.?
thks
invicta
Postby iadom » Tue Jan 22, 2008 4:34 pm
With extreme difficulty, its buried deep inside the machine, under the drum and just behind the motor. Access is rather awkward to say the least, removal of the drum is perhaps the best way to get at it TBH.
I have actually changed one without removing the drum, I had the scars for weeks afterwards.
Jim.
Postby invicta » Tue Jan 22, 2008 9:08 pm
Thks for that advice.
I have had the front off for a belt change but have never removed a drum.
Any advice on drum removal would be of help.
fred
invicta
Postby iadom » Tue Jan 22, 2008 10:24 pm
I would always remove the drum but leave the front in situ to change a belt.
If you have gone as far as removing the front in the past, then the the drum is only held on by a small pin through the drum shaft, you will find that behind the small cup shaped cover on the back.
Postby invicta » Mon Jan 28, 2008 9:26 pm
What a pain in the butt to fix!!
Virtually had to strip the machine down to get at the float that was stuck.
Fixed that and I now find that the auto temp reset thermistor has gone open circuit. LOL.
I also need to get some of the little plastic pegs that hold the sides on.
Any idea where I can get these from ?
invicta
Postby iadom » Mon Jan 28, 2008 11:11 pm
Part number C00095525, pack of six. Around £3.50 ex vat. An e-mail to spares@ukwhitegoods.co.uk would get you the pegs but there may be a few days delay. If you can find at least four of the old ones and put them back at the top and bottom of the side panels you should be OK.
No thermistors on these. :wink: The left hand stat at the back is the 'one shot' safety stat, the right hand stat is the temp control stat.
Two different kits for these stats, would need the first two numbers of the serial number to ID correct parts.
Jim.
Postby invicta » Tue Jan 29, 2008 10:47 am
Serial No is 71101723
From the front, the right hand stat has gone oc.
It has a green spot on it.
invicta
Postby iadom » Tue Jan 29, 2008 11:28 am
these are what you need.
Handle the green spot one with care, do not press on the base.
Jim.
Users browsing this forum: burton1972, Google [Bot], Google Adsense [Bot], Specialist01269 and 50 guests
In total there are 54 users online :: 4 registered, 0 hidden and 50 guests (based on users active over the past 30 minutes)
