by Allan » Fri Apr 22, 2005 6:56 am
I have recently moved into a flat that has a fitted washer dryer. The only problem is that the dryer cycle does not seem to produce any heat into the drum. The top of the machine casing however does warm up which would indicate that a heating element is working but the heat just does not appear to find its way into the drum.
Can you please offer any advise
Allan
by Martin » Fri Apr 22, 2005 7:05 am
Allan,
Very likely a few things need to be looked at, the blower fan, inlet valve, condenser ducting etc. Not a DIY job though I would suggest you see if we have someone in your area that can fix it for you (see link below). What is the model number of your machine by the way?
Repairs@
- Appliance Guru
by Allan » Fri Apr 22, 2005 10:31 am
Hi Martin
Its an Electrolux Aqualux EW 1200 I approx 5 years old.
Allan
by Martin » Fri Apr 22, 2005 12:26 pm
Allan wrote:Its an Electrolux Aqualux EW 1200 I approx 5 years old.
That's OK no problem, my earlier post applies, thanks for the info
- Appliance Guru
by Allan » Tue Apr 26, 2005 2:53 pm
Yes having checked out the possibilities the blower fan belt had come off. However when replaced it runs at only about 1 rev per second, which is not enough to drive the hot air through. Can you offer any further advice please.
Allan
by farmboy » Tue Apr 26, 2005 3:07 pm
Sounds like you may need a new ventilator (dryer fan)
Theres 2 types so you need to find the serial & product number (PNC)
farmboy
by Allan » Wed Apr 27, 2005 3:51 pm
The serial no is 95200030
Product No is 91467002200
Type P6417395
Allan
by yurtesen » Wed Apr 27, 2005 4:11 pm
can it be that something is stuck and thats why the belt went off at first place?
is the fan difficult to turn ? or the engine of the fan is turning slow even when the belt is not attached..?
yurtesen
- Regular Appliance Forum User
by RS » Wed Apr 27, 2005 4:18 pm
just send him a new washer martin and save time
RS
by Martin » Wed Apr 27, 2005 4:22 pm
RS wrote:just send him a new washer martin and save time
You'll get a slap in a minute Richard
- Appliance Guru
by yurtesen » Wed Apr 27, 2005 4:43 pm
I dont know what to say, funny...
yurtesen
by Allan » Thu Apr 28, 2005 5:49 am
A new washer dryer would be very nice but at £500 a time for the luxury of being built in its a non starter for such a small problem.
The blower fan turns freely its the motor that turns slowly with or without the drive belt fitted. What should the rpm of the motor be? What is likely to be the fault? Thanks Allan
Allan
by Martin » Thu Apr 28, 2005 7:06 am
Allan wrote:What should the rpm of the motor be?
Not sure of the fan motors speed (1,000rpm maybe?) but quite fast, so if the belt is removed and it runs slower than that, that's the fault sussed
A new one can be supplied by emailing us at
spares@ukwhitegoods.co.uk
quoting the part number : 1248254102.
- Appliance Guru
by Martin » Thu Apr 28, 2005 7:49 am
yurtesen wrote:What about the motor? Does it turn freely too?
Allan wrote:its the motor that turns slowly with or without the drive belt fitted.
:roll:
- Appliance Guru
by AMS » Thu Apr 28, 2005 8:29 am
As this is a shaded pole type motor, it should run at a nominal 2800 rpm
Dave
AMS
- Aqualux 1200 washer dryer
by dezzer » Sat Dec 02, 2006 6:42 pm
- 749 Views
- Last post by dezzer
Tue Dec 05, 2006 8:40 pm
- Aqualux EW 1200 washer dryer -no rinse or cold wash programs
by corimaman » Wed Dec 31, 2008 10:40 pm
- 529 Views
- Last post by corimaman
Fri Jan 02, 2009 11:47 am
- Electrolux 1200 - Aqualux 1200 EW1200
by bjstanbridge » Tue Jan 26, 2010 9:53 am
- 5 Replies
- 2173 Views
- Last post by iadom
Thu Jan 28, 2010 4:58 pm
- electrolux aqualux EW 1200i washer dryer not spinning
by cheeky » Wed Jan 04, 2006 10:18 pm
- 6 Replies
- 1228 Views
- Last post by cheeky
Thu Jan 05, 2006 9:23 pm
- Electrolux Aqualux EW 1200I Washer/Dryer - Drying problem
by Mackie » Sun Dec 17, 2006 8:39 pm
- 746 Views
- Last post by Kentish
Sun Dec 17, 2006 10:12 pm
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 15 guests
