by alastairbell » Tue Dec 14, 2004 2:58 pm
My Hoover AAA160 washing machine has decided to not rotate the drum... It started out as an intermittent problem. Anyone have any ideas? Do these machines have a brush type motor? Could that be the trouble?
thanks,
Alastair
alastairbell
- Appliance Forum User
by alastairbell » Tue Dec 14, 2004 4:01 pm
Thanks Martin. Are these available throught the shop? The full model no. from the ratings plate is AAA160-01.
Thanks!
alastairbell
by Martin » Tue Dec 14, 2004 4:07 pm
The Motor Brushes are Part No
97916670 and yes, should be available in "Shop@"
- Appliance Guru
by alastairbell » Wed Dec 22, 2004 11:10 am
I've had a look at the motor and brushes and they seem to be ok. There is about 1" or so of brush in the holder and they seem to touch the armature quite firmly. I'm now lost for ideas... any one else got any thoughts?
Thanks!
alastairbell
by Penguin45 » Wed Dec 22, 2004 11:14 am
Electronics........... Engineer time!
Check the Directories section, or pop up your post code and someone should pick up on it.
by alastairbell » Wed Dec 22, 2004 4:08 pm
Yeah I sort of guessed that. I do have a good grounding in electronics but in the abscence of a circuit diagram it makes it a bit tough to fault find! I have a sneaky feeling it may be the motor relay or control but as this is all mounted on a circuit board its a bit difficult to track any further... Postcode is LA1 2DB though....
alastairbell
by alastairbell » Sun Jan 16, 2005 5:51 pm
Hi all,
After a bit more playing around I found the problem (decided to have one last go before junking it and buying a new one)... The brushes were fine (as expected) as was the electronics (phew!). In the end I tracked it down to a faulty thermal cutout on the motor. Bypassed the cutout so all it needs now is a new motor. I have no idea why the cutout gave up as the motor doesn't get hot at all. So next question... how much and what is the part no. for a new motor?
Thanks!
Alastair
alastairbell
- Hoover HPM 130 drum won't turn
by GerryC » Thu May 03, 2007 11:22 pm
- 4 Replies
- 1225 Views
Fri May 04, 2007 11:30 pm
- Hoover AAA 1600 help and advice - drum does not turn
by DJBlack » Sat Oct 20, 2007 10:07 am
- 916 Views
- Last post by DJBlack
Sat Oct 20, 2007 3:52 pm
- Hoover Nextra HNC 1755 - drum won't turn
by m0nkeyb0y » Sat Oct 25, 2008 4:33 pm
- 39 Replies
- 3556 Views
- Last post by helo_75
Tue Dec 09, 2008 3:54 pm
- Hoover Nextra Hnl 6166 Drum not turn Help
by zomi » Sun Feb 12, 2012 11:45 am
- 386 Views
- Last post by zomi
Tue Feb 14, 2012 1:41 pm
- Hoover aaa160-01 problem..
by xandervitch » Tue Aug 10, 2004 6:03 pm
- 2058 Views
- Last post by xandervitch
Tue Aug 10, 2004 6:45 pm
Users browsing this forum: Google [Bot], joniboy69, SAMURI and 51 guests
