Roughly every third drying cycle, the front (of the two) thermostats trips. I power off, slide the machine out, top off, press the reset button - 'click' - put it all back and normal service is restored.
This is getting tedious and is starting to wear grooves in the flooring! My ears are also starting to suffer from the bending and bashing from my long suffering better half.
On previous occasions i've spent happy evenings stripping out the condenser unit from the back of the machine and removing the usual slime and lint. I've got close to opening the heater box out, but peering in I cannot see any flow obstruction at all. I've also split the bit where the fan lives and de-fluffed it.
If I *look* at things now, there doesn't seem to be any rubbish blocking the airflow anywhere I can see.
Pump is clear of rubbish and when the machine does a full drying run, the clothes are dry, so it all wants to work.
So i'm left with:
a) your suggestions
b) municipal tip and a hefty bill for a new, probably better engineered machine
c) thermostat is a little to trigger happy (I doubt this can really happen..?) and needs replacing
d) the airflow restriction is somewhere else I can't see - could there be enough rubbish inside the drum..?!
I'm going to pull the whole thing apart for a full inspection and de-fluff as a matter of course - but I would be very grateful for any further suggestions anybody might have for things I can look for.
Hopefully i've just missed a pile of filth in there...
