Washer stopped mid cycle and door locked light is flashing. Is it possible to test the door switch when it is off the washer. I have tried a continuity test on the switch terminal spades but when I operate the slider none of the spades have a circuit between them. Should they? or is there another way to test the switch before ordering a new one?
Could you also explain how the switch works inside, am I right in thinking it uses heat to keep the door locked?
Any help appreciated
Chris
