by HarryMay » Mon Jul 18, 2005 10:16 am
My Indesit has stopped half way thorugh cycle with error code F10
I have turned it off and restarted with no problems.
A couple of days later it has done the same now with error code -H20
Does anyone have an explanation of error codes F10 and -H20.
There has also been some random water leakage and the machine appears to be over filling with water.
Many thanks for any help given.
HarryMay
by Dave_Conway » Mon Jul 18, 2005 10:54 am
They are related faults, F10 is a water level sensor problem and H20 is a "no fill error".
Pressure switch is the most likely fault so not an overly expensive repair should that be the case.
Take a look at
Repairs@ if you'd like an engineer
by HarryMay » Wed Jul 20, 2005 11:33 am
Many thanks for your responce.
I have searched through the forum and found a simular fault.
The user "taylorclan90" said he had a split in the pressure pipe.
I opened up the top of my machine and only found one pipe which looking from the front of the machine ran from a sensor to the pump on the right hand side of the drum.
This pipe had foam rings protecting the pipe but these had moved and the pipe had been rubbing on the drum and created a flat spot and eventualy a small split.
Once the pipe split it gave an error warning of F10 (Pressure sensor warning)
You can clear this warning by turning off the machine and restarting but now the drum fills up over over 3/4 full and then gives a -H20 warning which is supposed to mean no water.
-H20 means "No H20" i.e the chemical symbol for water.
I have replaced this pipe and touch wood all is working fine again.
Harry
HarryMay
- INDESIT EVOLUTION 1600 WE16 - Not draining or spinning dry
by johnmilesfan » Sun Nov 20, 2005 2:13 pm
- 1001 Views
Sun Nov 20, 2005 6:31 pm
- Indesit Evolution 1600 WE16- Geting dirty clothes
by Dirtywash » Mon May 29, 2006 11:42 am
- 6 Replies
- 959 Views
Mon May 29, 2006 3:22 pm
- indesit evolution we16 error code: ' - con'
by Minty » Tue Jun 01, 2004 10:27 am
- 16 Replies
- 5817 Views
Sun Apr 24, 2005 5:09 pm
- indesit evolution we16 error code -h20
by robbied » Thu Aug 18, 2005 5:03 pm
- 1077 Views
- Last post by andy2
Fri Aug 19, 2005 4:25 pm
- indesit evolution 1600 error code H2O
by legz » Tue Jan 04, 2005 11:32 am
- 1199 Views
- Last post by Dave_Conway
Tue Jan 04, 2005 12:26 pm
Users browsing this forum: Google [Bot] and 28 guests
