Indesit WA121 flashing led's.
Postby Soapy » Sun May 13, 2012 6:16 pm
Today a fault has developed on our washing machine. It stops mid cycle and the red padlock led and the top and bottom green led's flash in a random pattern. The door won't open. If I turn the power off and on only the padlock led lights up. The machine can then be restarted on the wash cycle again. But then the problem happens again.
Any ideas people please?
Thank you
Paul.
Soapy
Postby Martin » Sun May 13, 2012 6:25 pm
Surprisingly enough the fault code indicated by the 2 green flashing lights refers to a : Door Lock Error. :wink:
So, replacing the 'door interlock' or checking it out at least your best way forward at this stage I would suggest. :D
Re: Indesit WA121 flashing led's.
Postby Soapy » Mon May 14, 2012 2:17 pm
Ok, thank you for your reply Martin. I thought the reply would be pcb fault & the machine would be a write off.
Managed to get the door open, sprayed loads of WD40 in the gap of the lock. Ran 1 cycle ok, then the next one same problem. Switched it off and on and ran a cycle and managed to get it finished after 11pm last night. Is the 'door interlock' the unit held on with 2 screws on the front on the right hand side? If so is it a simple task of purchasing another one and swapping it over to cure the fault?
By the way the red padlock led has been flashing for a couple of years now, but doesn't seem to affect operation.
Paul.
Soapy
Postby Martin » Mon May 14, 2012 3:24 pm
Soapy wrote:Is the 'door interlock' the unit held on with 2 screws on the front on the right hand side? If so is it a simple task of purchasing another one and swapping it over to cure the fault?
Yes, yes and very likely ( in that order) :D
Postby Soapy » Mon May 14, 2012 3:35 pm
Oh good, I have to source me one now. Might stop the wife moaning.
Thanks again Martin.
Paul.
Soapy
Postby Soapy » Fri Jan 25, 2013 10:04 pm
Hello Martin, I ordered a new part after the machine became progressively worse. Swapped the door lock mechanism, put it all back together and now the door won't latch shut, tried adjusting it to no avail, put the original one back and that won't latch either, but the machine can be started and run and the door will open. Help please.
Soapy
Users browsing this forum: No registered users and 12 guests
In total there are 12 users online :: 0 registered, 0 hidden and 12 guests (based on users active over the past 30 minutes)
