by Flight Boss » Fri Oct 22, 2004 7:27 pm
Can anyone tell me what the fault code F03 indicates.The machine is pumping out and filling at the same time and the drum is not moving. Is there and easy fix for a competant DIY'er? I'd be grateful for any advice.
regards
FB
Flight Boss
by eastlmark » Fri Oct 22, 2004 9:00 pm
I think you will find its related to the wash heater themistor. This is built into the heater and pretty much impossible to test without replacing it but you could check the wires leading to it. The code is only a guide though and does not nessesarily mean that this is the problem. Remember to isolate the machine from the mains before removing any panel or the lid.
eastlmark
by Flight Boss » Sat Oct 23, 2004 11:09 am
Top Man!
Well done Eastiman. You were absolutely right with your diagnosis.Stripped the machine down to find a red wire broken away from it's lucar connector at the heater. Five minutes with some wire strippers and a new connector and the machine is 'right as rain. I talked up my part to 'her indoors' and she thinks I'm a very clever chappie'. Might even get 'afters following dinner tonight.
Good one my son. Thanks for the tip'
FB
Flight Boss
by filbertfatknacker » Sun Oct 30, 2011 1:00 pm
the brown and black wire into a into a single connector that connected to the thermostat... looked fine .., i still stripped back the brown wire and reconnected it and it seem to have cured the problem, thanx all ..this was the 3rd serch i looked at on google. and as for the wife putting out ..maybe have to rewire her 2
filbertfatknacker
- WE16 fault code F-08
by wilky » Sat Oct 23, 2004 10:47 am
- 2038 Views
- Last post by Dave_Conway
Sat Oct 23, 2004 11:13 am
- indeset we16 fault code F05
by gaz » Sat Oct 23, 2004 9:00 pm
- 11 Replies
- 3311 Views
Tue Oct 26, 2004 11:17 pm
- Indesit WE16 Error code FO5
by zafira2 » Mon Jan 31, 2005 9:24 am
- 1564 Views
- Last post by Martin
Mon Jan 31, 2005 9:32 am
- Indesit WE16 error code
by wet washing » Tue Aug 02, 2005 5:53 pm
- 783 Views
- Last post by wet washing
Tue Aug 02, 2005 6:14 pm
- Indesit we16 Fault
by vicarjames » Sat Jan 03, 2004 12:46 pm
- 14 Replies
- 4387 Views
- Last post by shortie
Thu Feb 15, 2007 9:39 pm
Users browsing this forum: Google Adsense [Bot] and 64 guests
