by solid » Sun Aug 15, 2010 6:30 pm
I'm looking for a wiring diagram for the above model. I have a dry soldered joint on the circuit board of the programme selector dial and the machine doesn't spin. I have no power to the motor so wanted to know if the dry joint was related to the no spin problem.
Also have a problem where the drier gets hot and seems to work correctly but the clothes are still wet. Any ideas?
solid
- Appliance Forum User
by iadom » Sun Aug 15, 2010 7:51 pm
solid wrote:Hi
Rule 8 applies
Hopefully someone with knowledge of this particular machine may be able to help you.
A lot of Prima badged appliances are actually Whirlpool but some Whirlpool washer dryers are made by Smeg.
It can be a nightmare at times identifying the actual manufacturer of the machine.
by solid » Sun Aug 15, 2010 8:19 pm
Oh ok sorry i didn't see the rules. Thanks, i'll just test the system. Its ok it just takes longer thats all and i was looking for a short cut. Its only stopped working today and my multimeter is at work.
Any advise on the other fault would be good though.
solid
by iadom » Sun Aug 15, 2010 8:22 pm
If you have found a dry joint then re soldering it would be a good idea in any event.
by solid » Sun Aug 15, 2010 9:31 pm
iadom wrote:If you have found a dry joint then re soldering it would be a good idea in any event.
Yeah thanks, i am going to but as it was a sunday and i have no tools at home to solder with i thought i'd try source some info first.
solid
by solid » Mon Aug 16, 2010 1:12 pm
Just an update. Resoldered the dry connection and now all works fine. Thanks
solid
by iadom » Mon Aug 16, 2010 3:08 pm
Thanks for letting us know.
- Servis M9303 washer drier thermostats on drier duct
by tibsy » Fri Oct 15, 2010 11:24 am
- 489 Views
- Last post by tibsy
Wed Nov 03, 2010 7:10 pm
- Candy cnw 156 washer drier
by kaleja » Sat Dec 23, 2006 9:37 am
- 458 Views
- Last post by kaleja
Sat Dec 23, 2006 2:50 pm
- washer/drier advice
by acrt » Tue Apr 10, 2007 7:40 am
- 5 Replies
- 1472 Views
- Last post by don
Tue Apr 10, 2007 11:29 am
- APM 8703 Washer/Drier
by jellyhammer29 » Wed Jan 16, 2008 8:49 pm
- 907 Views
- Last post by jellyhammer29
Thu Jan 17, 2008 7:45 pm
- Bosch washer/drier
by Peter1933 » Thu Apr 19, 2012 1:34 pm
- 273 Views
- Last post by Peter1933
Thu Apr 19, 2012 2:48 pm
Users browsing this forum: No registered users and 9 guests
