by mgls » Sat May 19, 2012 11:01 am
Bosch WFT8010GB/01
Our usually trusty washer/dryer has been very temperamental recently. Having just replaced the carbon brushes last weekend, it is now spinning well (if I just put it on a spin programme), but it is zooming through its wash cycles spending about 30 seconds on each before advancing to the next step.
It sometimes seemed to be doing this fast cycling before I replaced the brushes but having managed to do 4 loads of washing since, I thought the new brushes had fixed it. Does anyone have any suggestions of anything else I can try, before I give up on the old war-horse and buy a new machine?
-Mike
mgls
by Martin » Sat May 19, 2012 12:11 pm
No simple answer to this question but firstly ensure that the dryer timer is OFF first of all otherwise that could simply be the problem. If the insulation reading is low on the motor that too could well be a problem. You say you changed the brushes, or did you fit a genuine Bosch motor rear half unit (part no. 496876) or just pattern carbons? A blocked air chamber or low insulation on the water heater needs to be ruled out also.
- Appliance Guru
by mgls » Mon May 21, 2012 10:41 am
Thanks for the advice. I only replaced the existing brushes with pattern carbon brushes.
It isn't so long since it has had a new heating element, and what I presume is the air chamber at the base of the drum rear is clear, so I think that I should perhaps try the genuine Bosch part (assuming it doesn't cost a fortune).
mgls
by Martin » Mon May 21, 2012 11:01 am
mgls wrote:so I think that I should perhaps try the genuine Bosch part (assuming it doesn't cost a fortune).
Best part of £60 they are so I would hold back from that move right now. Instead the insulation resistance of the motor needs checking (with a 500DCv Insulation Tester preferably) just to establish the actual state of the motor.
- Appliance Guru
by mgls » Mon May 28, 2012 2:20 pm
I've just had a local rewinding firm check the motor over. They said they blew lots of carbon out of it and it passed the insulation tests they made on it.
If I choose to go with the genuine Bosch motor rear half unit (part no. 496876) - where can I get that from? Are there any other avenues I can try?
mgls
by Martin » Mon May 28, 2012 4:03 pm
mgls wrote:I've just had a local rewinding firm check the motor over.
.....and they didn't notice if the brushes were worn down presumably?
mgls wrote:If I choose to go with the genuine Bosch motor rear half unit (part no. 496876) - where can I get that from?
Errr...click
CLICK HEREmgls wrote:Are there any other avenues I can try?
"avenues." ....you mean what else could be causing the fault if it's not the motor?
- Appliance Guru
- bosch wvt126gb/01 washer/dryer dryer not heating up
by gilesd » Wed Aug 06, 2008 11:25 am
- 639 Views
- Last post by gilesd
- Bosch WVT1260 washer dryer not heating on dryer
by martfoxy » Fri Apr 19, 2013 3:39 pm
- 247 Views
- Last post by martfoxy
Sun Apr 21, 2013 4:44 pm
- Bosch Washer/Dryer
by Plums » Tue Jul 11, 2006 8:10 am
- 448 Views
- Last post by Martin
Tue Jul 11, 2006 8:14 am
by amol_Karnik » Tue Jan 02, 2007 2:27 pm
- 5 Replies
- 889 Views
- Last post by amol_Karnik
Wed Jan 03, 2007 4:04 pm
- BOSCH WASHER DRYER NO DRY
by BROKENMAN » Wed Jun 04, 2008 6:58 am
- 849 Views
- Last post by nigegt
Wed Jun 04, 2008 10:32 am
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 96 guests
