by stuart_faust » Tue Feb 28, 2012 8:41 am
Hi i have a Hotpoint Aquarius WF541.
Its causing some some pain as when we plug it in sometimes it trips the electric for the whole house , sometimes just the downstairs sockets sometimes it allows you to have it plugged in and turn it on without tripping then after a few seconds of it starting on any form of wash it trips again.
Please can anyone help or advise on where to start?
stuart_faust
- Appliance Forum User
by nigegt » Tue Feb 28, 2012 8:50 am
Start at the heater. Test if insulation reading is poor and if so replace.
Nige
nigegt
- WTA Member
by stuart_faust » Tue Feb 28, 2012 8:54 am
ok thanks , when you say test if insulation reading is poor , how do i do that? i have a multimeter but no clue where to start if thats what you mean?
stuart_faust
by clivejameson » Tue Feb 28, 2012 8:54 am
Time to get a meter out and look for an earth fault, heater is the usual culprit but could be a number of other things.
Plug out at all times while working on it
clivejameson
- Appliance Forum Veteran
by stuart_faust » Sat Mar 03, 2012 11:01 am
hi , i tried disconnecting the brown cable to the heater and it still trips. how do i test the heater with the multimeter?
there is brown , green yellow and blue terminals.
stuart_faust
by iadom » Sat Mar 03, 2012 11:20 am
Please don't take offence but if you don't know how to use a multimeter or megger to do an insulation test then you REALLY should get someone who does know to have a look at it.
by stuart_faust » Sat Mar 03, 2012 12:41 pm
im after some basic help as im skint and cant afford to buy a new machine. or pay for an engineer. Thought that this place was for help.
stuart_faust
by iadom » Sat Mar 03, 2012 12:48 pm
stuart_faust wrote: Thought that this place was for help.
It is within the rules laid down
HEREa
Better skint then electrocuted.
by stuart_faust » Sat Mar 03, 2012 1:21 pm
please could you tell me how to test the heater. i have a multimeter but am not sure what terminals to test and how. should i be testing shorts across the heater?
stuart_faust
by stuart_faust » Sat Mar 03, 2012 1:34 pm
i get approx 30ohms from brown to blue. can i disconnect the heater completly and turn the electrics on and see if it trips. and if it trips its not the element?
stuart_faust
by stuart_faust » Tue Mar 06, 2012 8:45 am
Ive disconnected the heater element and the electrics in the house dont trip. the washing machine does not turn on at all , does this mean it should be the heater element that's at fault?
Any help would be great?
stuart_faust
by stuart_faust » Mon Mar 12, 2012 8:45 am
I have replaced the heating element and the washer still trips the electrics.
Any ideas?
stuart_faust
by Martin » Mon Mar 12, 2012 8:52 am
stuart_faust wrote:Any ideas?
There is an issue with the moulded 13amp plugs on these machines going faulty. I would suggest you cut off and discard the plug and replace it with a decent quality 13amp plug.
.jpg)
Please ignore the 3amp (red) fuse in the illustration, you'll need a 13amp (brown) fuse
- Appliance Guru
by stuart_faust » Mon Mar 12, 2012 8:55 am
Ok thanks ill try that.
stuart_faust
by stuart_faust » Tue Mar 13, 2012 8:27 am
Tried a new plug , trips the second i plug it in.
Any other ideas anyone?
Does anyone know if the washing machine should turn on with the heating element disconnected?
stuart_faust
- Washing machine tripping electrics out.
by gate8 » Tue Jul 10, 2012 1:09 pm
- 257 Views
- Last post by gate8
- zanussi zwf 12070w washing machine tripping electrics
by robalan » Mon Jan 12, 2009 5:33 pm
- 5 Replies
- 1048 Views
- Last post by robalan
Mon Jan 19, 2009 4:44 pm
- Tripping electrics
by Slegaby » Thu Apr 18, 2013 12:45 pm
- 7 Replies
- 195 Views
- Last post by Specialist01269
Thu Apr 18, 2013 3:01 pm
- New ISE W1607W tripping electrics
by frootloops » Wed Jul 04, 2012 5:19 pm
- 9 Replies
- 874 Views
- Last post by frootloops
Fri Jul 06, 2012 5:18 pm
- Hotpoint WM52 tripping the electrics?
by madasabadger » Thu Jan 12, 2006 9:52 pm
- 813 Views
- Last post by clivejameson
Thu Jan 12, 2006 10:03 pm
Users browsing this forum: Google Adsense [Bot], Soulman and 72 guests
