Trying to sort my son's WD640. It tripped the circuit breaker in the house after 1 or 2 seconds, every time he powered it on. After browsing here, I disconnected the heater element, and it's fine. So I suspect an earth fault in the heater circuit - but is it the heater or something else I made open circuit by disconnecting the heater?
My meter shows about 1MegaOhm between the disconnected heater terminals and earth, which doesn't look bad but I don't really know what to expect on insulation. Heater itself is 44 Ohms which is about what I'd expect.
Should I buy a new heater element and try it or are there some more diagnostics I can try first?
