by parttimepar » Thu Oct 26, 2006 7:57 pm
Hi All,
I have just registered with this site and I have previously used Ezee but I can no longer access it, has it closed down? I have a fault similar to that of Pot Noodle submitted on the 27th of September, however I have a different model number. On the 40 synthetic and rapid wash cycles the machine stops with several buttons flashing and will not restart until the control knob is turned to off which of course means starting from scratch on a new cycle! I have cleaned out the filter regularly. There is also almost always a little puddle of water on the floor after each wash and I cannot figure out where this is coming from! I have cleaned out the powder drawer. I would appreciate any possible solutions from this excellent site.
parttimepar
- Appliance Forum User
by Penguin45 » Thu Oct 26, 2006 11:51 pm
L -R, which buttons........?
by parttimepar » Wed Nov 01, 2006 5:27 pm
Hi Penquin45,
Thanks for responding, the buttons which flash are 'Drain Spin, 100 and 0'.
parttimepar
by parttimepar » Fri Nov 10, 2006 10:44 pm
Can anyone help me here?
parttimepar
by Penguin45 » Sat Nov 11, 2006 12:27 am
I presume these are from the column of lamps down the right? If you could number them 1-5 starting at the top as to which ones are lit, we might be able to narrow this down. The Whirlpool tech info doesn't give us the luxury of the names of the lamps illuminated
Thanks,
by SparkyP » Sat Nov 11, 2006 3:59 pm
Hi There,
Sounds like the bottom 2 lights which indicate FP failure which is the drain time out. Have you checked the filter. (Possible blockage inside the tub and drum or a sock caught in the sump hose or even a 5p piece stuck in the pump outlet hole. If its not the filter it will be engineer time i'm afraid)
Sparkyp
SparkyP
by parttimepar » Fri Nov 17, 2006 10:10 am
Hi All,
There is a row of six buttons along the centre top of which 'drain spin' is fifth from left and a column of five buttons on RH side of which '100 and 0' are the bottom two. I have checked and cleaned the filter regularly. Will now have a look at the possibilities Sparkyp has highlighted. What is FP?
Thanks parttimepar
parttimepar
by SparkyP » Sat Nov 18, 2006 5:43 pm
Hi There Parttimepar
The FP i refer to is the error code thet is displayed on the digital versions of the whirlpool appliance. As yours is not digital it displays flashing lights to tell an enginneer in which direction to look.
Those in the know will know where to look. It is defo a blockage as your water will not drain out or drain out very slowly. Worst case a faulty pump.
Sparkyp
SparkyP
by WhirlpoolLes » Mon Nov 20, 2006 5:07 pm
These machines are renowned for "swallowing" socks which will get stuck in the sump hose, not making down as far as the filter.
WhirlpoolLes
- Whirlpool 6120/3
by Magic02 » Sun Dec 07, 2008 6:15 pm
- 622 Views
- Last post by Magic02
Wed Dec 10, 2008 5:09 pm
- Whirlpool 6120-6k W/Machine
by parttimepar » Thu Apr 01, 2010 2:35 pm
- 627 Views
- Last post by parttimepar
Sat Apr 03, 2010 8:01 am
- Zanussi FLA 1001W or Whirlpool AWM 6120?
by Toftwatson » Fri Sep 24, 2010 9:32 pm
- 369 Views
- Last post by Toftwatson
- whirlpool awm 6120/1 washing machine
by mbriody » Sat Jun 16, 2012 10:32 am
- 353 Views
- Last post by mbriody
Sat Jun 23, 2012 9:21 pm
- Siemens 6120 error code 1
by taj » Thu Sep 13, 2007 8:36 pm
- 10 Replies
- 2060 Views
- Last post by gegsy
Wed Sep 19, 2007 5:54 pm
Users browsing this forum: No registered users and 14 guests
