whirlpool AWO/D 4505 wont spin
by telemek » Wed Jul 29, 2009 8:29 am
This machine washes fine but when in the spin cycle it distributes the load then starts a slow spin then stops then repeats and stops until end of cycle.
Tried it with no load on spin only cycle and it will go to a fast spin for a few seconds then stop and repeat but the whole cycle is very short (about 1 minute).
Any help with this would be greatly appreciated.
telemek
Regular Forum User
Regular Forum User
Does your washing machine stink?
If your washing machine stinks, smells bad or emits strange odours it is most likely to be caused by bacteria build up in the washer. To clean this we recommend using Affresh that you can buy here to clean out the bacteria. And for more detailed advice on washing machine odour you can read our article all about smelly washing machines here
Buy Affresh washing machine cleaner here to stop bad smells from your washing machine
by Payney » Wed Jul 29, 2009 9:38 am
This sounds like there is a problem with the tacho on the motor. Could need replacing. If you are looking yourself make sure you are safe and always unplug while checking.
Hope this helps.
Payney
Regular Forum User
Regular Forum User
by telemek » Wed Jul 29, 2009 10:17 am
Hi Payney
Thanks for your reply, I will check tacho coil & connections.
Graham
telemek
Regular Forum User
Regular Forum User
