Zanussi ZWG1120M - E62 code
by corimaman » Sun Apr 14, 2013 2:21 pm
I found the machine had stopped mid cycle and was displaying E62 code. When I tried getting it going again the motor was working but it was intermittent as if there was a loose connection somewhere. I have had the back off and checked the big white connector to the motor and no sign of loose connection and the contacts are good. Tracing the loom up to the back of the control board I checked the connections there too. The load in the drum at the time the machine failed was towels and they may have been too heavy for what the machine can handle. Has anyone got any suggestions as to to what's gone wrong?
corimaman
 Washing machine drain pumps & parts
If your washing machine will not drain the cause will normally be that either your drain pump is blocked or faulty resulting in the machine failing to empty. You can buy replacement drain pump including many low cost compatible washing machine pumps in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
Drain pumps for most washing machines including popular makes like AEG, Hotpoint, Beko, Baumatic, Bosch and many more
by Specialist01269 » Sun Apr 14, 2013 2:41 pm
Hi: If I remember correctly the E62 error on your machine shows that it's detected an overheating problem during the wash cycle. It could be due to a faulty thermistor or possibly a faulty control PCB.
Let us fix it properly.
Specialist01269
by corimaman » Sun Apr 14, 2013 5:22 pm
Hi Specialist01260 - thanks for your reply, are you able to direct me to the suspect thermistor and when you say it could be the control board, is that a case of replacing the whole board, the one on the back of the control fascia?
corimaman
by Specialist01269 » Sun Apr 14, 2013 6:15 pm
Hi Drew: Unfortunately the thermistor is built into the heating element & not available as a separate part, the element on these is pretty pricey. If you follow the wiring from the thermistor to the control board you can check the plug / socket connections for it, if it is a control pcb fault then unless you can get it repaired then the only option is replacement & I would'nt even like to think how much the pcb is. Your best option in the long run may be to call a local engineer to check the machine for you.
Specialist01269
by corimaman » Mon Apr 15, 2013 12:27 pm
Hi - thanks for your advice but going back to the symptoms how does an overheating problem cause the motor to be intermittent? I know E62 is the code for overheating but could Zanussi have changed this?
corimaman
by Specialist01269 » Mon Apr 15, 2013 12:43 pm
Have you checked the motor brushes ?
Specialist01269
 No water into your washing machine?
If your washing does not fill up with water then it is likely that your water supply is faulty or the water fill valve in your machine is. Find replacement water valves in our store including many low cost compatible fill valves for all major brands such as Hoover, Hotpoint, Beko, AEG and more
Buy washing machine water valves and other washing machine spare parts
