Announcement
Collapse
No announcement yet.
Candy integrated fridge CRU 160 EK temperature problem
Collapse
Qualtex
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Candy integrated fridge CRU 160 EK temperature problem
    We have a integrated Candy fridge - CRU 160 EK. The problem is that the fridge does not seem to be cooling unless we set it to the coldest setting (7). But keeping it on this setting means it freezes the food as it seems to run continuously. If we click it to 7 then down again it seems to work for a bit and then turn off automatically - but then it doesn't turn on again. So we've been manually triggering it ever few hours to keep the food cold.
    It would be great to know whether this is fixable (by myself or a trades-person) or whether we need to scrap it.
    Thanks!
  • #2
    sounds like the thermostat has failed. you will probably find if you set the temp and let it get down to temp. when it does not start again all you have to do is tap the knob firmly and it will start
    had a few stats fail this way
    Dave
    Comment
    Cheap Spare Parts
    Collapse
    Affresh
    Collapse
    Working...
    X
