Announcement
Collapse
No announcement yet.
Panasonic = Gasket Warped After 2 Months + EcoNavi Setting
Collapse
Qualtex
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Findcount
    replied
    Originally posted by electrofix View Post
    then you may see a lot of the engineers
    but keep all the paperwork in case you have to make a point later
    but at the moment its not your problem as they have to pay for it
    Dave
    could be my usual bad luck when it comes to buying things.............used to it by now
    Leave a comment:
  • electrofix
    replied
    Dave
    Leave a comment:
  • Findcount
    replied
    are you saying this unit is 2 months old from new
    if yes then any problems will be covered by the guarantee and it should not be up to you to fix it ( unless its down to misuse )
    Dave
    yes, under warranty..........but i reckon the gasket problem will resurface even after replacement.........i wonder how the gasket could warp after just 2 months since gaskets should be the last thing to worry about !
    Leave a comment:
  • electrofix
    replied
    Dave
    Leave a comment:
  • Panasonic = Gasket Warped After 2 Months + EcoNavi Setting
    hi,
    hope Panasonic users here can help........would i save more energy if i left the fridge + freezer on EcoNavi (Medium) temperature setting............or put fridge + freezer on Minimum temperature setting ?
    also, after just 2 months...............the bottom corner of the freezer door's gasket is warped..........allowing little cold air to escape - how can i fix this ?
    many many thanks for any useful info..............
Cheap Spare Parts
Collapse
Affresh
Collapse
Working...
X
