Announcement
Collapse
No announcement yet.
Bosch WTA4409GB/03 Tumble Dryer
Collapse
Qualtex
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Bosch WTA4409GB/03 Tumble Dryer
    Hi,
    I recently replaced the heating element in the above, after it stopped heating up.
    It then worked fine for a few weeks, but has now stopped heating up again. Assuming it's not the element again, according to the Bosch manual there are 3 or 4 thermostats / temperature regulators, and at £40-£70 each I don't want to buy them all!.
    Is thermostat P/N 423039 the most likely culprit, or does anyone have any other recommendations / advice?.
    Many thanks
    Peter
  • #2
    get a multimeter, set it on the buzz setting
    taking each thermostat in turn, disconnect 1 wire then touch the terminals to both sides of the stat. if it buzzes its ok, reconnect wire and try the next one
    do any of these stats have a reset button ?
    Dave
    Comment
    • #3
      Many thanks Dave, very helpful.
      Haven't seen a reset button. Will test later today and get back to you.
      Thanks again
      Peter
      Comment
      • #4
        Hello Dave,
        Turned out to be that little red reset button you suggested I looked for.
        Many thanks for your help
        Peter
        Comment
        Cheap Spare Parts
        Collapse
        Affresh
        Collapse
        Working...
        X
